[postgis-devel] JDBC & WKB - 400% overhead
Paul Ramsey pramsey at refractions.net
Tue Feb 22 11:35:49 PST 2005
This is with an ascii cursor, yes?
I wonder why they chose such a fluffy representation for the bytea
canonical form.
P.
dblasby at openplans.org wrote:
> I was checking to see if the WKB (postgis 1.0) was actually transiting
> "in binary" from the server (postgresql 8) to a JDBC (also postgresql
> 8) client.
> ResultSet rs2 = st.executeQuery("select 5::float8,asBinary('POINT(0
> 0)')");
> rs2.next();
> byte[] bs = rs2.getBytes(2);
> assertTrue(bs.length == 21);
> The WKB representation of a 'POINT(0 0)' is 21 bytes long (1 byte for
> xdr/ndr flag, 4 bytes for type, and 2 8-byte doubles = 21 bytes).
> If you step through the executeQuery() command in the postgresql driver,
> you'll eventually end up in PGStream#ReceiveTupleV3().  This is where
> the actual data is received from the database.
> It clearly receives 84 bytes of data from the server.  This is the bytea
> text representation:
> \001\001\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000
> The ResultSet#getBytes() function converts this to a byte[].
> dave
> This mail sent through IMP: https://webmail.limegroup.com/
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
