[postgis-devel] JDBC & WKB - 400% overhead
Markus Schaber schabios at logi-track.com
Wed Feb 23 06:57:37 PST 2005
[X-Post to better place for discussion]
Hi, David,
dblasby at openplans.org schrieb:
> I was checking to see if the WKB (postgis 1.0) was actually transiting
> "in binary" from the server (postgresql 8) to a JDBC (also postgresql
> 8) client.
> ResultSet rs2 = st.executeQuery("select 5::float8,asBinary('POINT(0 0)')");
> rs2.next();
> byte[] bs = rs2.getBytes(2);
> assertTrue(bs.length == 21);
> The WKB representation of a 'POINT(0 0)' is 21 bytes long (1 byte for
> xdr/ndr flag, 4 bytes for type, and 2 8-byte doubles = 21 bytes).
> If you step through the executeQuery() command in the postgresql driver,
> you'll eventually end up in PGStream#ReceiveTupleV3().  This is where
> the actual data is received from the database.
> It clearly receives 84 bytes of data from the server.  This is the bytea
> text representation:
> \001\001\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000
> The ResultSet#getBytes() function converts this to a byte[].
Maybe your postgresql driver only uses text transfer up to now.
asBinary() returns a byte array, so this should be transferred more
efficiently.
Can you try the following query:
select 5::float8,asBinary('POINT(0 0)')::bytea
Maybe the current 8.0-310 build has fixed this. But the pgsql-jdbc list
could be the better place to ask this question, IMHO, so I forward it to
there.
Markus
markus schaber | dipl. informatiker
logi-track ag | rennweg 14-16 | ch 8001 zürich
phone +41-43-888 62 52 | fax +41-43-888 62 53
mailto:schabios at logi-track.com | www.logi-track.com
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20050223/af2ad419/attachment.pgp>
