[postgis-devel] Manual make html fails
strk at refractions.net strk at refractions.net
Tue Jan 11 00:26:46 PST 2005
Fixed, thanks.
--strk;
On Mon, Jan 10, 2005 at 03:54:40PM +0100, Markus Schaber wrote:
> Hello,
> Just a small report:
> With current CVS, building the HTML version of the manual fails:
> schabi at kingfisher:~/workspace/postgis/doc$ make clean
> schabi at kingfisher:~/workspace/postgis/doc$ make html
> cat postgis.xml | sed "s/@@LAST_RELEASE_VERSION@@/0.8/g" > postgis-out.xml
> xsltproc \
>         --output html/postgis.html \
>         --param shade.verbatim 1 \
>         --param section.autolabel 1 \
>         --param section.label.includes.component.label 1 \
>         --param chunk.section.depth 0 \
>         --stringparam html.stylesheet style.css \
>         /usr/share/xml/docbook/stylesheet/nwalsh/html/docbook.xsl \
>         postgis-out.xml
> Error: no ID for constraint linkend: geometry_dump.
> HTH,
> markus
> markus schaber | dipl. informatiker
> logi-track ag | rennweg 14-16 | ch 8001 z├╝rich
> phone +41-43-888 62 52 | fax +41-43-888 62 53
> mailto:schabios at logi-track.com | www.logi-track.com
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
For standing up against patentability of software,
  Thank You, Poland!
Read the intervention:    http://kwiki.ffii.org/ConsPolon041221En
Send your thanks:         thankyoupoland.info
Read/do more:		  http://www.noepatents.org/
