[postgis-devel] PATCH: New positional operators based on Y position of bounding boxes
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Tue Jan 11 03:11:58 PST 2005
Happy New Year everyone! :)
Here is a patch against CVS that addresses a slightly strange omission from
the operators included with PostGIS. One of our import scripts had
accidentally created some geometries with very large Y coordinates (e.g.
POINT(0 1E20)) and in order to delete these rows, I had to select
geometeries above a certain Y-coordinate which is currently not implemented
in PostGIS as an indexable operator (I gave up waiting for over half an hour
for a SELECT... ORDER BY... to complete on a multi-million row table,
whereas it is already possible to do this in seconds on the X-axis using the
<< and >> operators).
This patch implements the following additional operators for PostGIS, with
the ability to use a GiST index where one exists:
	A <<| B
		The bounding box of A is strictly below the bounding box of
B
	A &<| B
		The bounding box of A vertically overlaps or is below the
bounding box of B
	A |>> B
		The bounding box of A is strictly above the bounding box of
B
	A |>& B
		The bounding box of A vertically overlaps or is above the
bounding box of B
(to make sense of these operators, it may help to tilt your head 90 degrees
to the right, where the | character represents the X-axis).
I've posted this for review instead of applying directly since I know Paul
was considering reducing the number of operators included in PostGIS. I have
done some simple tests using both sequential and index scans, and confirmed
that the new operators return the expected results. Comments anyone?
Kind regards,
Mark.
WebBased Ltd
South West Technology Centre
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 791021
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20050111/22e1a7ff/attachment.obj>
