[postgis-devel] RC2 ?
strk at refractions.net strk at refractions.net
Tue Jan 25 06:20:11 PST 2005
This is a list of changes since RC1 is out:
        - More correct STABLE, IMMUTABLE, STRICT uses in lwpostgis.sql
        - GEOMETRYCOLLECTION(EMPTY) syntax support for backward compatibility
        - faster and more robust loader (both i18n and not)
        - faster binary outputs
        - bug fix in pointarray box3d computation
        - initial autoconf script
        - bug fix in distance_spheroid definition
        - stricter OGC WKB constructors
        - stricter OGC WKT constructors
        - bug fix in transform() missing to update bbox cache
What do you think about an RC2 release ?
Also, do you think we should jump over autoconf ?
--strk;
