[postgis-devel] RC2 ?
Markus Schaber schabios at logi-track.com
Tue Jan 25 06:29:39 PST 2005
Hi, strk,
strk at refractions.net schrieb:
> This is a list of changes since RC1 is out:
>         - More correct STABLE, IMMUTABLE, STRICT uses in lwpostgis.sql
>         - GEOMETRYCOLLECTION(EMPTY) syntax support for backward compatibility
>         - faster and more robust loader (both i18n and not)
>         - faster binary outputs
>         - bug fix in pointarray box3d computation
>         - initial autoconf script
>         - bug fix in distance_spheroid definition
>         - stricter OGC WKB constructors
>         - stricter OGC WKT constructors
>         - bug fix in transform() missing to update bbox cache
Great work!
Do not forget that we now have JDBC support working again :-)
> What do you think about an RC2 release ?
I think there's enough change to justify another RC, yes.
> Also, do you think we should jump over autoconf ?
I did not yet have enough time to test it (I'm currently rather busy
with other things), but what mileage did the others report?
Markus
markus schaber | dipl. informatiker
logi-track ag | rennweg 14-16 | ch 8001 zürich
phone +41-43-888 62 52 | fax +41-43-888 62 53
mailto:schabios at logi-track.com | www.logi-track.com
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20050125/5955cf30/attachment.pgp>
