[postgis-devel] ICONV autodetection (head branch)
Jean David TECHER davidtecher at yahoo.fr
Mon Jul 4 05:04:25 PDT 2005
Yes Master!!! :-)
cvs checkout postgis
I applied my patch for windows
and let in postgis/Makefile.config.in
USE_ICONV=@USE_ICONV@
I got
for configure
 SUMMARY
 HOST_OS: mingw32
   PGSQL: /c/PostgreSQL/8.0.3/bin/pg_config
    GEOS: /c/PostgreSQL/8.0.3/bin/geos-config
    PROJ: dir=/c/PostgreSQL/8.0.3/bin/..
   ICONV: 0
 PORTNAME: win32
   PREFIX: /usr/local
  EPREFIX: ${prefix}
      DOC: ${prefix}/share/doc
     DATA: ${prefix}/share/postgresql/contrib
      MAN: ${prefix}/man
      BIN: c:/PostgreSQL/8.0.3/bin
      EXT: c:/PostgreSQL/8.0.3/lib (\$$libdir)
Hum....!!! The only problem is to be able to have lwpostgis.sql and spatial_ref_sys.sql in the same directory og PG SHAREDIR
Not really a goog idea!!! It's better to let postgis-prefix=/usr/local by default
I will copy *.sql done by postgis manually (*.sql + doc + man)
ok thanks :-)
However Sandro I think it will be a great idea to let for win32 Path_to_PosttGIS_library = $lidbir even if user give '--prefix=...' when he uses configure
I mean for win32 it's better to have
EXT     = (\$$libdir)
instead of
EXT   :=   ${exec_prefix}/$/libexec when we use configure
So I will not have to replace EXT by libdir in lwpostgis.sql since PostgreSLQ doesn't support /c/ in path
TECHER Jean David
01MAP
e-mail: david at 01map.net
Tél: 04 67 45 60 27
Entreprise: http://www.01map.net
Perso: http://techer.pascal.free.fr/postgis/
  ----- Original Message -----
  To: PostGIS Development Discussion
  Sent: Monday, July 04, 2005 11:48 AM
  Subject: [postgis-devel] ICONV autodetection (head branch)
  On Thu, Jun 30, 2005 at 10:36:11AM +0200, Jean David TECHER wrote:
  > Sorry for iconv I've had problem so I put USE_ICONV=0 in postgis/Makefile.config.in
  > Make and make install works fine!!!
  I've reworked iconv detection code to be more conservative.
  It should now be enabled only if the c library provide that functionality.
  (no external libiconv supported).
  This should remove the need of manually edit Makefile.config
  --strk;
  postgis-devel mailing list
  postgis-devel at postgis.refractions.net
  http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20050704/5cc7a84a/attachment.html>
