[postgis-devel] relief of dependency on postgresql sources
alex bodnaru alexbodn at 012.net.il
Sat Jun 4 04:42:20 PDT 2005
hi strk,
good to see you back.
thanks for uploading my work. just note, that jdbc2 will be broken until
patched.
needless to say, that the package builds and runs on a debian machine,
with only the api headers installed.
btw, if you have unstandard configuration, you could pass
--with-config=[your installed pg_config full name] to autoconf, and i
hope it will work for you. (if i really understand autoconf from this
first time impact).
best regards,
alex
On Sat, 2005-06-04 at 12:17 +0200, strk at refractions.net wrote:
> Alex, thank you for your work. I've committed your patch to easy
> further testing (head branch).
> The jdbc2/Makefile separated one is not there yet, Markus, could you
> apply it yourself ?
> I think next step should be having path names match the 1.0.1 layout
> and to test with different pgsql versions/configurations. I have
> no default installation of pgsql, if anyone does tests against
> them would be highly appreciated.
> --strk;
> On Tue, May 31, 2005 at 02:44:10PM +0200, Markus Schaber wrote:
> > Hi, Alex,
> > alex bodnaru wrote:
> > > here is a diff you could use for jdbc2/Makefile, instead of the
> > > previous.
> > > i have tested it and works ok (i am using the Makefile.config
> > > functionality).
> > > i would be grateful if you could test with it for the special cases you
> > > know about.
> > In my tests, it built the jar files and ran the tests without having a
> > ../Makefile.config.
> > Great work.
> > As this patch seems to depend on those for the non-jdbc Makefiles, I
> > will not commit it now, but I think it should be committed with the others.
> > > p.s. the moment we merge those changes, i can already send a new and
> > > slim debian package for postgis-1.1.
> > > current packages are at http://packages.qa.debian.org/p/postgis.html.
> > Great!
> > Markus
> > postgis-devel mailing list
> > postgis-devel at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
