[postgis-devel] relief of dependency on postgresql sources
alex bodnaru alexbodn at 012.net.il
Sat Jun 4 04:59:24 PDT 2005
On Sat, 2005-06-04 at 13:52 +0200, strk at refractions.net wrote:
> > btw, if you have unstandard configuration, you could pass
> > --with-config=[your installed pg_config full name] to autoconf, and i
> > hope it will work for you. (if i really understand autoconf from this
> > first time impact).
> That is --with-pgsql, right ?
yes, of course. sorry.
alex
> --strk;
> > best regards,
> > alex
> > On Sat, 2005-06-04 at 12:17 +0200, strk at refractions.net wrote:
> > > Alex, thank you for your work. I've committed your patch to easy
> > > further testing (head branch).
> > > The jdbc2/Makefile separated one is not there yet, Markus, could you
> > > apply it yourself ?
> > > I think next step should be having path names match the 1.0.1 layout
> > > and to test with different pgsql versions/configurations. I have
> > > no default installation of pgsql, if anyone does tests against
> > > them would be highly appreciated.
> > > --strk;
> > > On Tue, May 31, 2005 at 02:44:10PM +0200, Markus Schaber wrote:
> > > > Hi, Alex,
> > > > alex bodnaru wrote:
> > > > > here is a diff you could use for jdbc2/Makefile, instead of the
> > > > > previous.
> > > > > i have tested it and works ok (i am using the Makefile.config
> > > > > functionality).
> > > > > i would be grateful if you could test with it for the special cases you
> > > > > know about.
> > > > In my tests, it built the jar files and ran the tests without having a
> > > > ../Makefile.config.
> > > > Great work.
> > > > As this patch seems to depend on those for the non-jdbc Makefiles, I
> > > > will not commit it now, but I think it should be committed with the others.
> > > > > p.s. the moment we merge those changes, i can already send a new and
> > > > > slim debian package for postgis-1.1.
> > > > > current packages are at http://packages.qa.debian.org/p/postgis.html.
> > > > Great!
> > > > Markus
> > > > _______________________________________________
> > > > postgis-devel mailing list
> > > > postgis-devel at postgis.refractions.net
> > > > http://postgis.refractions.net/mailman/listinfo/postgis-devel
