[postgis-devel] More JDBC2 fun....
Markus Schaber markus at schabi.de
Tue Mar 29 05:22:22 PST 2005
Hi, Mark,
Mark Cave-Ayland schrieb:
>>>I also had to make one minor modification to the Makefile in order to
>>>get the offline tests to run correctly after compilation:
>>>	RUNCP=$(POSTGIS_BUILD_CLASSPATH)$(CPSEP)./postgis.jar
>>>Without the ./ in front of postgis.jar, the JAR file could not be
>>>found when launching the offline tests.
>>It works for me, and I don't think that this change would
>>break another jre.
>>But I learned to triple-check before I check this change in.
>>Alex, could you have a look at it? Strk, and everyone else,
>>does this work for you?
> The reason I resurrected this thread is that the same setup described above
> was used to successfully compile the JDBC2 driver for RC5 on the first
> attempt, i.e. CSEP set to : and the ./ in front of postgis.jar. Anyone else
> have any experience with this?
As there's no feedback up to now, I'll check the change into CVS.
Markus
