[postgis-devel] postgresql sources dependency relieved
strk at refractions.net strk at refractions.net
Tue May 24 02:03:57 PDT 2005
Alex, I'd commit your patches if that will make your
debugging easier. What do you think ?
--strk;
On Tue, May 24, 2005 at 11:44:57AM +0300, alexbodn at 012.net.il wrote:
> you should first do: make Makefile.config.
> please reply with any problems.
> alex
> ----- Original Message -----
> From: strk at refractions.net
> Date: Tuesday, May 24, 2005 10:19 am
> Subject: Re: [postgis-devel] postgresql sources dependency relieved
> > Thank you alex. I've applied your patch - manually handling
> > rejected part for printwkb.c.
> > This is an error I get running ./configure && make:
> > make[1]: Circular all-shared-lib <- liblwgeom.so.1.1 dependency
> > dropped.measures.o box2d.o ptarray.o lwgeom_api.o lwgeom.o
> > lwpoint.o lwline.o lwpoly.o lwmpoint.o lwmline.o lwmpoly.o
> > lwcollection.o   wktunparse.o lwgparse.o wktparse.tab.o lex.yy.o
> > vsprintf.o liblwgeom.o lwgeom_pg.o lwgeom_debug.o
> > lwgeom_spheroid.o lwgeom_ogc.o lwgeom_functions_analytic.o
> > lwgeom_nojts.o lwgeom_inout.o lwgeom_estimate.o
> > lwgeom_functions_basic.o lwgeom_gist.o lwgeom_btree.o
> > lwgeom_transform.o stringBuffer.o lwgeom_box.o lwgeom_box3d.o
> > lwgeom_box2dfloat4.o lwgeom_chip.o lwgeom_svg.o lwgeom_gml.o
> > lwgeom_triggers.o lwgeom_dump.o  -shared  -L/usr/bin/../lib -lproj
> > -o liblwgeom.so.1.1
> > make[1]: measures.o: Command not found
> > make[1]: *** [liblwgeom.so.1.1] Error 127
> > --strk;
> > On Tue, May 24, 2005 at 05:19:49AM +0300, alex bodnaru wrote:
> > > hi,
> > > the diff is attached.
> > > i have made it against not the very latest cvs snapshot.
> > > alex
> > > On Mon, 2005-05-23 at 14:25 +0300, alexbodn at 012.net.il wrote:
> > > > hi strk, listers,
> > > > as promised, i am happy to announce that i have totally
> > > > relieved the postgis making dependency on postgresql
> > > > sources.
> > > > now are needed only current headers, and Makefile.shlib,
> > > > preferrably from latest postgresql.
> > > > i have successfully tested postgis 1.1.0cvs with postgresql
> > > > 7.4.x and Makefile.shlib from postgresql 8.0.x. or 7.4.x.
> > > > the diffs might be isolated by tonight (gmt+2), and i will try
> > them
> > > > on older postgis, too.
> > > > alex
> > > > _______________________________________________
> > > > postgis-devel mailing list
> > > > postgis-devel at postgis.refractions.net
> > > > http://postgis.refractions.net/mailman/listinfo/postgis-devel
