[postgis-devel] postgresql sources dependency relieved
alex bodnaru alexbodn at 012.net.il
Tue May 24 09:36:11 PDT 2005
there was a small dependency problem as you said, but postgis built
well.
anyway, the problem is fixed by now, and new diff included.
please recheck.
alex
On Tue, 2005-05-24 at 11:03 +0200, strk at refractions.net wrote:
> Alex, I'd commit your patches if that will make your
> debugging easier. What do you think ?
> --strk;
> On Tue, May 24, 2005 at 11:44:57AM +0300, alexbodn at 012.net.il wrote:
> > you should first do: make Makefile.config.
> > please reply with any problems.
> > alex
> > ----- Original Message -----
> > From: strk at refractions.net
> > Date: Tuesday, May 24, 2005 10:19 am
> > Subject: Re: [postgis-devel] postgresql sources dependency relieved
> > > Thank you alex. I've applied your patch - manually handling
> > > rejected part for printwkb.c.
> > > This is an error I get running ./configure && make:
> > > make[1]: Circular all-shared-lib <- liblwgeom.so.1.1 dependency
> > > dropped.measures.o box2d.o ptarray.o lwgeom_api.o lwgeom.o
> > > lwpoint.o lwline.o lwpoly.o lwmpoint.o lwmline.o lwmpoly.o
> > > lwcollection.o   wktunparse.o lwgparse.o wktparse.tab.o lex.yy.o
> > > vsprintf.o liblwgeom.o lwgeom_pg.o lwgeom_debug.o
> > > lwgeom_spheroid.o lwgeom_ogc.o lwgeom_functions_analytic.o
> > > lwgeom_nojts.o lwgeom_inout.o lwgeom_estimate.o
> > > lwgeom_functions_basic.o lwgeom_gist.o lwgeom_btree.o
> > > lwgeom_transform.o stringBuffer.o lwgeom_box.o lwgeom_box3d.o
> > > lwgeom_box2dfloat4.o lwgeom_chip.o lwgeom_svg.o lwgeom_gml.o
> > > lwgeom_triggers.o lwgeom_dump.o  -shared  -L/usr/bin/../lib -lproj
> > > -o liblwgeom.so.1.1
> > > make[1]: measures.o: Command not found
> > > make[1]: *** [liblwgeom.so.1.1] Error 127
> > > --strk;
> > > On Tue, May 24, 2005 at 05:19:49AM +0300, alex bodnaru wrote:
> > > > hi,
> > > > the diff is attached.
> > > > i have made it against not the very latest cvs snapshot.
> > > > alex
> > > > On Mon, 2005-05-23 at 14:25 +0300, alexbodn at 012.net.il wrote:
> > > > > hi strk, listers,
> > > > > as promised, i am happy to announce that i have totally
> > > > > relieved the postgis making dependency on postgresql
> > > > > sources.
> > > > > now are needed only current headers, and Makefile.shlib,
> > > > > preferrably from latest postgresql.
> > > > > i have successfully tested postgis 1.1.0cvs with postgresql
> > > > > 7.4.x and Makefile.shlib from postgresql 8.0.x. or 7.4.x.
> > > > > the diffs might be isolated by tonight (gmt+2), and i will try
> > > them
> > > > > on older postgis, too.
> > > > > alex
> > > > > _______________________________________________
> > > > > postgis-devel mailing list
> > > > > postgis-devel at postgis.refractions.net
> > > > > http://postgis.refractions.net/mailman/listinfo/postgis-devel
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20050524/b9a120aa/attachment.bin>
