[postgis-devel] relief of dependency on postgresql sources
alex bodnaru alexbodn at 012.net.il
Fri May 27 18:35:24 PDT 2005
hello friends,
i have just finished a few improvements to postgis-cvs, meant to
completely relieve the dependency on postgresql sources.
this contains import of Makefile.shlib from postgresql, and the
mechanism to determine the postgresql portname, mandir and docdir.
other cleanups have been needed (make maintainer-clean was failing) etc.
i have successfully tested this framework under debian sarge, with
postgresql 7.4.x, with Makefile.shlib from postgresql 8.0.x.
please check this patch for your environment, and feel free to send your
input.
best regards,
alex
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20050528/89919888/attachment.bin>
