[postgis-devel] shp2pgsql and shapefiles without vertices
Markus Schaber schabi at logix-tt.com
Tue Nov 1 03:47:13 PST 2005
Hi, Strk,
strk at refractions.net schrieb:
> Note that intended behaviour has always been _a_bort if shapefile
> contains ONLY null geometries. The check has always been there, but
> it contained a bug: return code from SHPReadObject() was checked
> for NULL (error condition) rather then for nVertices()==0
> (see revision 1.88.2.5).
Oh, then this is a longtime-unnoticed bug that turned into a feature for
the users :-)
> Rather then drop the check (which require double scan of the
> shapefile, and also leaked memory) I just plugged the memory
> leak and fixed the bug.
> I've implemented the 3-option switch you suggest in HEAD.
> 	-N insert, -Ni
> 	-N skip, -Ns
> 	-N abort, -Na
Thanks.
> As for 1.0 I'd just drop the first scan as a whole, to fix
> the back-compatibility issue. Comments ?
Sounds good.
Thanks,
Markus
