[postgis-devel] Transform() PROJ4 cache patch
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Fri Nov 4 03:41:55 PST 2005
> -----Original Message-----
> From: 'strk' [mailto:strk at keybit.net]
> Sent: 04 November 2005 11:32
> To: Mark Cave-Ayland (External)
> Cc: postgis-devel at postgis.refractions.net
> Subject: Re: [postgis-devel] Transform() PROJ4 cache patch
> Thanks for timing Mark.
> It seems there's no much to gain from invoking
> transform_geometry directly in terms of performance. Still,
> I'd keep it as users might want to perform reprojection even
> w/out a spatial_ref_sys table. There's no work involved in
> keeping it, so what's the point of removing it ?
> --strk;
Hi strk,
Okay. Keeping everything in the original style (everything in
lwgeom_transform.c) patch means it's now just a cut and paste job to keep
the old code. When I get a moment, I'll rework the patch and post it back to
the list for final review before commit.
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
