[postgis-devel] Transform() PROJ4 cache patch
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Sat Nov 5 08:03:33 PST 2005
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On
> Behalf Of Mark Cave-Ayland
> Sent: 04 November 2005 11:42
> To: 'strk'
> Cc: postgis-devel at postgis.refractions.net
> Subject: RE: [postgis-devel] Transform() PROJ4 cache patch
(cut)
> Okay. Keeping everything in the original style (everything in
> lwgeom_transform.c) patch means it's now just a cut and paste
> job to keep the old code. When I get a moment, I'll rework
> the patch and post it back to the list for final review before commit.
Hi strk,
Hopefully this should be the last version before commit - I've attached the
patch against CVS HEAD for testing. Here are the timings from a different
box:
BEFORE
postgis11=# \timing
Timing is on.
postgis11=# select count(transform(geom, 4326)) from test;
 count
 500000
(1 row)
Time: 445359.010 ms
AFTER
postgis11=# \timing
Timing is on.
 count
 500000
(1 row)
Time: 5077.462 ms
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20051105/a8428599/attachment.obj>
