[postgis-devel] pgsql2shp integer length
Paul Ramsey pramsey at refractions.net
Tue Jul 11 11:12:00 PDT 2006
We noticed that when exporting an "integer" field from postgis to shape,
the dumper was giving the dbf field a type of "number(11,0)". When the
same file is imported into GRASS, it interprets it as a float
(presumably because it is theoretically possible to overrun a 32-bit
integer with 11 digits of numerals). GRASS will happily read the same
file with a type of "number(10,0)" as an integer rather than a float.
We are converting "integer" -> "number(11,0)" which will fit the widest
possibility ("-2147483648").  It looks like GRASS (or, more
particularly, GRASS's v.in.ogr) is assuming that integers are only up to
10 digits.
Shapefiles, I despise thee.
