[postgis-devel] loader/dumper tests support
strk at refractions.net strk at refractions.net
Sat Jun 17 04:54:25 PDT 2006
On Fri, Jun 16, 2006 at 09:55:13AM -0600, Michael Fuhr wrote:
> With all of the above changes, Solaris/sparc fails the mlines tests:
>  loader/mlines2d... failed (wkb insert: diff expected obtained: /tmp/pgis_reg_2180/test_1_diff)
>  loader/mlines3dz... failed (wkb insert: diff expected obtained: /tmp/pgis_reg_2180/test_2_diff)
>  loader/mlines3dm... failed (wkb insert: diff expected obtained: /tmp/pgis_reg_2180/test_3_diff)
>  loader/mlines4d... failed (wkb insert: diff expected obtained: /tmp/pgis_reg_2180/test_4_diff)
> I've attached one of the diffs -- is it a byte order problem?
Thanks a lot Mike, I've committed a new revision of the shell script
with all the suggested changes. In addition I changed the interface
to *require* explicit .sql files for testing, so to not rely anymore
on the canonical output.
Tests for all supported shapefile formats have been added.
I'd release postgis 1.1.3 late next week, so all tests are welcome.
--strk;
