[postgis-devel] ready for 1.1.6 ?
strk at refractions.net strk at refractions.net
Thu Nov 2 01:57:31 PST 2006
On Thu, Nov 02, 2006 at 10:35:27AM +0100, Markus Schaber wrote:
> >>  wktunparse.c: In function 'unparse_WKB':
> >>  wktunparse.c:580: warning: comparison is always false due to limited range of data type
> > Could you try using an explicit cast:
> > -       if ( endian == -1 )
> > +       if ( endian == (char)-1 )
> It seems that Ingo is on Holidays now, and I don't have access to that
> machine, but I'll see whether I can change that.
Note that I committed this patch already, needs only to be tested.
Best would be adding a regress test which would fail in a precedent
release (if possible)
--strk;
