[postgis-devel] 8.3devel cast changes causing regression failures
Mark Cave-Ayland
mark.cave-ayland at ilande.co.uk
Fri Jun 8 03:31:17 PDT 2007
On Wed, 2007-06-06 at 08:41 -0600, Michael Fuhr wrote:
> The attached patch fixes the regression failures against 8.3devel;
> I've tested it against 8.2.4, 8.1.9, and 8.0.13 as well. The
> regression tests themselves didn't need fixing; the problems were
> in some of the library functions. I'll review the code more closely
> when I get a chance to see if I missed anything that the regression
> tests aren't covering (in which case we should probably add some
> new tests).
Looks good to me. Committed.
Many thanks,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
