[postgis-devel] [Fwd: Rethinking user-defined-typmod before it's too late]
Stephen Frost sfrost at snowman.net
Fri Jun 15 10:11:07 PDT 2007
* Mark Cave-Ayland (mark.cave-ayland at ilande.co.uk) wrote:
> Thought this would be interesting for fellow developers - as of 8.3,
> there is now the facility to specify a typmod as part of a user-defined
> type, e.g.
> CREATE TABLE foo AS (
> 	id bigint,
> 	the_geom geometry(4326)
> This could have some interesting uses for defining geometries with
> coordinates systems and dimensionality....
Even better, what Tom's proposing is making it a string, where you could
then have something like:
the_geom geometry(4326,POLYGON,2)
Or at least, I think that's the case, and I've sent a follow-up email on
this thread asking him about it already. :)
	Thanks,
		Stephen
Content-Description: Forwarded message - Rethinking user-defined-typmod before it's too late
> Date: Fri, 15 Jun 2007 12:14:45 -0400
> From: Tom Lane <tgl at sss.pgh.pa.us>
> To: pgsql-hackers at postgreSQL.org
> Subject: Rethinking user-defined-typmod before it's too late
> The current discussion about the tsearch-in-core patch has convinced me
> that there are plausible use-cases for typmod values that aren't simple
> integers.  For instance it could be sane for a type to want a locale or
> language selection as a typmod, eg tsvector('ru') or tsvector('sv').
> (I'm not saying we are actually going to do that to tsvector, just that
> it's now clear to me that there are use-cases for such things.)
> Teodor's work a few months ago generalized things enough so that
> something like this is within reach.  The grammar will actually allow
> darn near anything for a typmod, since the grammar production is
> expr_list to avoid shift/reduce conflict with the very similar-looking
> productions for function calls.  The only place where we are
> constraining what a typmod can be is that the defined API for
> user-written typmodin functions is "integer array".
> At the time that patch was being worked on, I think I argued that
> integer typmods were enough because you'd have to pack them into such a
> small output representation anyway.  The hole in that logic is that you
> might have a fairly small enumerated set of possibilities, but that
> doesn't mean you want to make the user use a numeric code for them.
> You could even make the typmod be an integer key for a lookup table,
> if the set of possibilities is not hardwired.
> Since this code hasn't been released yet, the API isn't set in stone
> ... but as soon as we ship 8.3, it will be, or at least changing it will
> be orders of magnitude more painful than it is today.  So, late as this
> is in the devel cycle, I think now is the time to reconsider.
> I propose changing the typmodin signature to "typmodin(cstring[]) returns
> int4", that is, the typmods will be passed as strings not integers.  This
> will incur a bit of extra conversion overhead for the normal uses where
> the typmods are integers, but I think the gain in flexibility is worth
> it.  I'm inclined to make the code in parse_type.c take either integer
> constants, simple string literals, or unqualified names as input ---
> so you could write either tsvector('ru') or tsvector(ru) when using a
> type that wants a nonintegral typmod.
> Note that the typmodout side is already OK since it is defined to return
> a string.
> Comments?
> 			regards, tom lane
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20070615/dc9bec1a/attachment.sig>
