[postgis-devel] [Fwd: Rethinking user-defined-typmod before it's	too late]
    Paul Ramsey
    pramsey at refractions.net
    Fri Jun 15 10:36:16 PDT 2007
Praise Tom!
Lots of handy uses for this... I wonder if we can have it be overloaded, so
geometry just gives you an unconstrained geometry
geometry(srid) gives you an srid constraint
geometry(srid,type) gives you ...
etc
And we could then finally make geometry columns a simple view against
the system tables (maybe, not sure how that would work with views).
P
Stephen Frost wrote:
> * Mark Cave-Ayland (mark.cave-ayland at ilande.co.uk) wrote:
>> Thought this would be interesting for fellow developers - as of 8.3,
>> there is now the facility to specify a typmod as part of a user-defined
>> type, e.g.
>> CREATE TABLE foo AS (
>> 	id bigint,
>> 	the_geom geometry(4326)
>> This could have some interesting uses for defining geometries with
>> coordinates systems and dimensionality....
> Even better, what Tom's proposing is making it a string, where you could
> then have something like:
> the_geom geometry(4326,POLYGON,2)
> Or at least, I think that's the case, and I've sent a follow-up email on
> this thread asking him about it already. :)
> 	Thanks,
> 		Stephen
> Content-Description: Forwarded message - Rethinking user-defined-typmod before it's too late
>> Date: Fri, 15 Jun 2007 12:14:45 -0400
>> From: Tom Lane <tgl at sss.pgh.pa.us>
>> To: pgsql-hackers at postgreSQL.org
>> Subject: Rethinking user-defined-typmod before it's too late
>> The current discussion about the tsearch-in-core patch has convinced me
>> that there are plausible use-cases for typmod values that aren't simple
>> integers.  For instance it could be sane for a type to want a locale or
>> language selection as a typmod, eg tsvector('ru') or tsvector('sv').
>> (I'm not saying we are actually going to do that to tsvector, just that
>> it's now clear to me that there are use-cases for such things.)
>> Teodor's work a few months ago generalized things enough so that
>> something like this is within reach.  The grammar will actually allow
>> darn near anything for a typmod, since the grammar production is
>> expr_list to avoid shift/reduce conflict with the very similar-looking
>> productions for function calls.  The only place where we are
>> constraining what a typmod can be is that the defined API for
>> user-written typmodin functions is "integer array".
>> At the time that patch was being worked on, I think I argued that
>> integer typmods were enough because you'd have to pack them into such a
>> small output representation anyway.  The hole in that logic is that you
>> might have a fairly small enumerated set of possibilities, but that
>> doesn't mean you want to make the user use a numeric code for them.
>> You could even make the typmod be an integer key for a lookup table,
>> if the set of possibilities is not hardwired.
>> Since this code hasn't been released yet, the API isn't set in stone
>> ... but as soon as we ship 8.3, it will be, or at least changing it will
>> be orders of magnitude more painful than it is today.  So, late as this
>> is in the devel cycle, I think now is the time to reconsider.
>> I propose changing the typmodin signature to "typmodin(cstring[]) returns
>> int4", that is, the typmods will be passed as strings not integers.  This
>> will incur a bit of extra conversion overhead for the normal uses where
>> the typmods are integers, but I think the gain in flexibility is worth
>> it.  I'm inclined to make the code in parse_type.c take either integer
>> constants, simple string literals, or unqualified names as input ---
>> so you could write either tsvector('ru') or tsvector(ru) when using a
>> type that wants a nonintegral typmod.
>> Note that the typmodout side is already OK since it is defined to return
>> a string.
>> Comments?
>> 			regards, tom lane
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
   Paul Ramsey
   Refractions Research
   http://www.refractions.net
   Phone: 250-383-3022
   Cell: 250-885-0632
