[postgis-devel] Fedora postgis build problems revisited
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Fri Jun 22 01:35:59 PDT 2007
On Sun, 2007-06-17 at 00:33 +0300, Devrim GÜNDÜZ wrote:
> Hello,
> We have talked about this before; but I now have time to follow up it.
> Here is the problem:
> http://pgsql.privatepaste.com/5a0VSHpU7I
> # java --version
> java version "1.5.0"
> gij (GNU libgcj) version 4.1.2 20070502 (Red Hat 4.1.2-12)
> What can we do to fix this? I'd like to push postgis to Fedora.
> Regards,
Hi Devrim,
Unfortunately it looks as if Markus (our resident Java expert) isn't
around at the moment, so I'll try my best to answer. There was a bug
which was fixed in SVN which caused the Makefile to always try and build
the JTS jar even if JTS wasn't installed.
Does the Makefile from SVN solve your problem -
http://svn.refractions.net/postgis/trunk/java/jdbc/Makefile ?
BTW, would it cause you any packaging problems if the JDBC driver was
changed to use Ant instead of make?
Kind regards,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
