[postgis-devel] Re: [postgis-users] installation problem
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Thu May 10 08:30:43 PDT 2007
On Thu, 2007-05-10 at 11:25 -0400, vamsee movva wrote:
> HI mark,
> I tried what you told,
> But no luck, Is there any alternative (Note: i don't have root
> privileges)
> Thanks
Can you double-check that? Did you do a "make clean", alter the
GNUMakefile, and then do "make install" again? Note that it would be
possible to help you better if you post the output you are getting to
the list. FWIW the change you need to undo is the templategis changes to
GNUMalefile from this commit:
http://postgis.refractions.net/pipermail/postgis-commits/2007-January/000018.html.
Kind regards,
Mark.
