[postgis-devel] Conversion from box3d to box2d changes bounds
Charlie Savage cfis at savagexi.com
Sat Sep 22 16:13:28 PDT 2007
> BOX2DFLOAT4 *
> box3d_to_box2df(BOX3D *box)
>     result->xmin = nextDown_f(box->xmin);
>     result->xmax = nextUp_f(box->xmax);
> Notice it *intentionally* changes the bounding box.  I assume there is a
> good reason for this, but curious what it is.
Ah - its the double to float conversion.  Ok - so envelope works now by
checking the bounds in 2d, using this method:
getbox2d_p(SERIALIZED_FORM(geom), &box)
It seems that needs to change to use the 3d box as provided by this method:
compute_serialized_box3d_p(SERIALIZED_FORM(geom), &box)
This avoids the down-conversion and returns the correct results.
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20070922/3df1d8ad/attachment.bin>
