[postgis-devel] Conversion from box3d to box2d changes bounds
Charlie Savage cfis at savagexi.com
Sat Sep 22 15:58:46 PDT 2007
More of fixing up the envelope function.  It turns out the approach
Martin suggested for Envelope (take the bounds of the geometry, then use
that to figure out the return geometry type) doesn't actually work in
PostGis.
Example:
select astext(envelope('POINT(-104.967648983002
39.7123038862956)'::geometry))
"POLYGON((-104.967651367188 39.7123031616211,-104.967651367188
39.7123069763184,-104.967643737793 39.7123069763184,-104.967643737793
39.7123031616211,-104.967651367188 39.7123031616211))"
It should be a point.  A bit of digging shows why.
First:
select box3d('POINT(-104.967648983002 39.7123038862956)'::geometry)
"BOX3D(-104.967648983002 39.7123038862956 0,-104.967648983002
39.7123038862956 0)"
This is ok.  But this is not:
select box2d('POINT(-104.967648983002 39.7123038862956)'::geometry)
"BOX(-104.967651367188 39.7123031616211,-104.967643737793 39.7123069763184)"
Notice that the box2d is no longer a point - and that the bounds have
changed?  Its because the this function:
BOX2DFLOAT4 *
box3d_to_box2df(BOX3D *box)
	result->xmin = nextDown_f(box->xmin);
	result->xmax = nextUp_f(box->xmax);
Notice it *intentionally* changes the bounding box.  I assume there is a
good reason for this, but curious what it is.
If this is correct, then it means my patch to Envelope needs to change
to recognize if a geometry is a point (versus just checking the bounding
box as it does now).
Thoughts?
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20070922/3edaa412/attachment.bin>
