[postgis-devel] Issue 74 in postgis: AddGeometryColumn does not detect search_path properly
codesite-noreply at google.com codesite-noreply at google.com
Tue Dec 2 12:12:25 PST 2008
Updates:
	Status: Fixed
Comment #2 on issue 74 by ke... at refractions.net: AddGeometryColumn does not
http://code.google.com/p/postgis/issues/detail?id=74
QA appreciated.
A fix is still required for DropGeometryColumn, DropGeometryTable, and
UpdateGeometrySRID.
	addgeometrycolumn.patch  10.1 KB
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
