[postgis-devel] Re: [postgis-users] how to identify the_geom that cause : RelateOperation called withLWGEOMCOLLECTION type
Kevin Neufeld kneufeld at refractions.net
Tue Dec 9 11:50:52 PST 2008
Thanx Mark,
Here's an updated patch.  I didn't put the truncation logic in a separate function yet since I'm not sure about freeing
the memory of a returned char* (looking through the code, sometimes pfree is called, and other times it's not).
Cheers,
Kevin
Mark Cave-Ayland wrote:
> Kevin Neufeld wrote:
>> Mark,
>> Is it fairly trivial to change the elog in lwgeom_geos.c to your fancy
>> errhint so that when the error is thrown the user has an idea where
>> the problem occurs?
> Yeah sure. In fact, elog() has been deprecated for a very long time and
> so in theory we should be using ereport() everywhere.
>> The attached patch seems to work, but I got lost when trying to limit
>> the output of the LWGEOMCOLLECTION to the first say 128 characters of
>> the WKT representation.
> Yup, code looks good. The only comment is that you want
> PARSER_CHECK_NONE instead of PARSER_CHECK_ALL, otherwise the conversion
> will fail on a non-OGC compliant geometry. So in other words, you only
> really want PARSER_CHECK_ALL on the input/output functions.
> In terms of truncating the output, you need to do this manually - see
> http://svn.refractions.net/postgis/trunk/lwgeom/lwgeom_pg.c:pg_parser_errhint
> for the code I used, although if it is needed in multiple places it may
> be a good idea to make this a separate function available in liblwgeom.
> HTH,
> Mark.
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081209/2fb9c117/attachment.ksh>
