[postgis-devel] Updates to GEOS & POSTGIS
Ben Jubb benjubb at refractions.net
Mon Jan 21 13:24:39 PST 2008
Ill implement your first suggestion, and stub the C functions for the
prepared stuff, moving the version detection to the lwgeom_geos_c.c.
Seems friendliest to the long suffering VS users.
b
Paul Ramsey wrote:
> Historically, we've left sql.in along and put in stubbed functions in
> the .c files, in the case of with-GEOS versus without-GEOS.  We could
> go whole hog and add GEOS version detection to ./configure.  Might
> make things even worse for VCC workers.
> As of now, having trolled the code base, there is a geos_version.sh
> script which can write the version into a #define for use elsewhere.
> The only running code that works with version is the run-time version
> print-out in postgis_geos_version().
> The most elegant thing would be to put it into ./configure, IMO, but
> I'm not sure that's the most *useful* thing.
> P
> On Jan 21, 2008, at 11:45 AM, Ben Jubb wrote:
>> My changes won't build against the GEOS 3.0.0 branch.  use the trunk
>> instead.
>> I'm open to suggestions as to how to get the GEOS version information
>> into lwpostgis.sql.in.
>> cheers
>> b
>> Mark Cave-Ayland wrote:
>>> On Fri, 2008-01-18 at 09:26 -0800, Ben Jubb wrote:
>>>> Mark,
>>>> thanks for the comments,
>>>> - I'll change the comment style..
>>>> - added the initGEOS() calls, oops..
>>>> - the size calculation: ill try your suggestion for getting
>>>> arg1_length.
>>> Hi Ben,
>>> I've just done a checkout of latest SVN, and unfortunately it seems
>>> broken against the GEOS 3.0.0 branch :(
>>> I managed to get around the compilation failures by removing the line
>>> "#define PREPARED_GEOM 0", but regression tests fail because
>>> lwpostgis.sql.in still references these functions, and hence it
>>> fails to
>>> load into PostgreSQL.
>>> So in order to support both newer and older versions of GEOS, there
>>> needs to be some GEOS versioning directives around the new code in both
>>> lwpostgis.sql.in and lwgeom_geos_c.c (rather than having to alter both
>>> of these by hand).
>>> ATB,
>>> Mark.
>> <benjubb.vcf>_______________________________________________
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20080121/cf5ac225/attachment.vcf>
