[postgis-devel] Rebranding proposal for SVN HEAD
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Thu Jul 3 06:50:01 PDT 2008
Obe, Regina wrote:
> I guess its fine as long as it doesn't break everything.
> I've always been kind of confused by the lwpostgis.sql name since I keep
> on looking for a postgis.sql.
It won't break anything, although it will make applying patches against
older PostGIS sources a bit harder. I can't say that I can see us
getting many large patches against older versions though ;)
> As a side note:
> I was hoping we would have a separate sql file for the function comments
> though and was hoping to modify the postgis docs so that I we can have a
> separate xsl file to tease the comments out of the docs into meta data
> inserts. More on that later.
> With that said - postgis_core.sql, postgis_comments.sql or something
> would make me slightly happier, but then again its not that much better.
I can't say that I'm too excited about that one - I like just being able
to have an active PostGIS database with a single psql command. OTOH it
should be possible to generate a single.sql file from multiple sources
as part of the build process if that helps?
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
