[postgis-devel] Docbook ID's and <a name> links
Kevin Neufeld kneufeld at refractions.net
Mon Jul 14 14:37:12 PDT 2008
:)  That's a good point.  I hadn't considered that.  I wonder if there
is a way to specify the filename used ... I suspect so, but clearly more
investigation is in order.
-- Kevin
Paul Ramsey wrote:
> Hm, goodish and badish... the direct links are nice, the fact that the
> names are meaningless is not, particularly since inserting a new
> function will probably result in the re-numbering of all the other
> pages...
> P.
