[postgis-devel] Docbook ID's and <a name> links
Kevin Neufeld kneufeld at refractions.net
Mon Jul 14 14:40:45 PDT 2008
Yup, we can.
http://docbook.sourceforge.net/release/xsl/current/doc/html/use.id.as.filename.html
-- Kevin
Kevin Neufeld wrote:
> :)  That's a good point.  I hadn't considered that.  I wonder if there
> is a way to specify the filename used ... I suspect so, but clearly more
> investigation is in order.
> -- Kevin
> Paul Ramsey wrote:
>> Hm, goodish and badish... the direct links are nice, the fact that the
>> names are meaningless is not, particularly since inserting a new
>> function will probably result in the re-numbering of all the other
>> pages...
>> P.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
