[postgis-devel] ST_Area, ST_Area2D
Obe, Regina robe.dnd at cityofboston.gov
Fri Jul 18 07:57:20 PDT 2008
Same silliness with ST_Perimeter (except we have both a ST_Perimeter2D
and ST_Perimeter() documented)
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Friday, July 18, 2008 10:35 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] ST_Area, ST_Area2D
Undocument it, and note that it is deliberately undocumented in the
.sql.in file, so we don't go and re-document it in the future.
On Fri, Jul 18, 2008 at 5:36 AM, Obe, Regina <robe.dnd at cityofboston.gov>
wrote:
> Can I scrap ST_Area2D from docs and just replace with ST_Area? or is
> ST_Area2D really the preferred name?  They both map to
> LWGEOM_area_polygon, but
> the docs list the ST_Area2D one which seems a bit more verbose and
> unconventional.
> Both IBM and ESRI on quick search just call it ST_Area
> IBM -
publib.boulder.ibm.com/infocenter/db2luw/v9/topic/com.ibm.db2.udb.spatia
> l.doc/rsbp4034.html
> and Esri
webhelp.esri.com/arcgisserver/9.3/java/geodatabases/st_area.htm
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
