[postgis-devel] ST_Area, ST_Area2D
Obe, Regina robe.dnd at cityofboston.gov
Mon Jul 21 04:09:39 PDT 2008
Good point.  That's exactly what I was thinking that if I'm working with
3d data, most of the time if I ask for a ST_Length(..) I expect a 3d
length and 2d I would never expect to get more than 2D, but I wasn't
sure if the specs somehow required ST_Length() should return a 2D length
Is their a penalty to doing a force_2d() though that would be more
efficiently done with an
ST_Length(geom, [dim])
If so then I would suggest we go with Paul's idea, but instead of
assuming No Dim means 2, that No Dim means the highest dimension (shall
we say -1 so we have only one backend function to contend with).
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mark
Sent: Monday, July 21, 2008 5:07 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] ST_Area, ST_Area2D
Paul Ramsey wrote:
> Optional argument? :)
> st_length(geom, [dim])
> default is 2d regardless of input, [dim] = 3 allows you to get 3d if
> you need it.
> P
Hmmm that seems like a lot of extra clutter. My feeling would be that
the result returned should reflect the highest dimension input geometry,
so as Regina suggests would be 2D length for a 2D line or 3D length for
a 3D line. In terms of compliance, anyone inputting 3D geometries is
already outside of the SFS 1.1 spec, and so I wouldn't feel bad about
asking people to add a force_2d() call to switch the result if the 2D
result is what they actually wanted. Common sense would suggest that if
you have a 3D input, you'll get a 3D output.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
T: +44 870 608 0063
postgis-devel mailing list
postgis-devel at postgis.refractions.net
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
