[postgis-devel] ST_Area, ST_Area2D
Paul Ramsey pramsey at cleverelephant.ca
Fri Jul 18 12:19:43 PDT 2008
Optional argument? :)
st_length(geom, [dim])
default is 2d regardless of input, [dim] = 3 allows you to get 3d if
you need it.
P
On Fri, Jul 18, 2008 at 10:27 AM, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
> Okay so we document all 3 variants or 2 variants (and if 2 which to keep
> ST_Length2D() or ST_Length())
> ST_Length2D(), ST_Length3D()
> Almost seems as if ST_length() should return 2D length for a 2D line and 3D
> length for a 3d line (which would suggest mapping it to the ST_Length3D(),
> but I guess that may violate OGC specs but all docs I have read seem vague
> on the matter.  We don't even have these listed as OGC compliant but all
> Spatial Dbs seem to have it but don't seem to discuss distinction between 2D
> and 3D).  Although its not documented at all so I suppose we can leave as
> such.
> But that is inconsistent with our documenting all 3 variants of Perimeter
> ST_perimeter(geometry)
> Returns the 2-dimensional perimeter of the geometry, if it is a polygon or
> multi-polygon.
> ST_perimeter2d(geometry)
> multi-polygon.
> ST_perimeter3d(geometry)
> Returns the 3-dimensional perimeter of the geometry, if it is a polygon or
> multi-polygon.
> ________________________________
> From: postgis-devel-bounces at postgis.refractions.net on behalf of Paul Ramsey
> Sent: Fri 7/18/2008 11:06 AM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] ST_Area, ST_Area2D
> length3d should return a different result for a 3d line than
> lenght2d... and we do need both variants, since sometimes you want the
> 2d legth of a 3d line.
> P.
> On Fri, Jul 18, 2008 at 7:55 AM, Obe, Regina <robe.dnd at cityofboston.gov>
> wrote:
>> Paul,
>> Ditto for these too?  ESRI and IBM just refer to this as ST_Length
>> --Docs have ST_Length2D and 3D but no ST_Length
>> ST_length2d(geometry)
>>    Returns the 2-dimensional length of the geometry if it is a
>> linestring or multi-linestring.
>> Just replace with ST_Length()?
>> Both ST_Length() and ST_Length2d() map to -
>> LWGEOM_length2d_linestring
>> Now ST_Length3D() maps to LWGEOM_length_linestring
>> Which on closer tests - gives me the same answer as ST_Length() for a
>> 2-d string.
>> Is there a reason why we can't just have a single documented
>> ST_Length and state it works for both 2D and 3D strings?  and in future
>> versions just have all 3 map to LWGEOM_length_linestring
>> and deprecate the 2D and 3D names?
>> Thanks,
>> Regina
>> -----Original Message-----
>> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
>> Ramsey
>> Sent: Friday, July 18, 2008 10:35 AM
>> Undocument it, and note that it is deliberately undocumented in the
>> .sql.in file, so we don't go and re-document it in the future.
>> On Fri, Jul 18, 2008 at 5:36 AM, Obe, Regina <robe.dnd at cityofboston.gov>
>> wrote:
>>> Can I scrap ST_Area2D from docs and just replace with ST_Area? or is
>>> ST_Area2D really the preferred name?  They both map to
>>> LWGEOM_area_polygon, but
>>> the docs list the ST_Area2D one which seems a bit more verbose and
>>> unconventional.
>>> Both IBM and ESRI on quick search just call it ST_Area
>>> IBM -
>> publib.boulder.ibm.com/infocenter/db2luw/v9/topic/com.ibm.db2.udb.spatia
>>> l.doc/rsbp4034.html
>>> and Esri
>> webhelp.esri.com/arcgisserver/9.3/java/geodatabases/st_area.htm
>>> The substance of this message, including any attachments, may be
>>> confidential, legally privileged and/or exempt from disclosure
>>> pursuant to Massachusetts law. It is intended
>>> solely for the addressee. If you received this in error, please
>>> contact the sender and delete the material from any computer.
>>> postgis-devel mailing list
>>> postgis-devel at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
