[postgis-devel] Function names in PostGIS
Obe, Regina robe.dnd at cityofboston.gov
Mon Jul 21 04:15:39 PDT 2008
I had the same thought too, but thought it would be too confusing to people to go back and change all those so didn't care to voice the concern.  Moving forward is a good idea I think.
It is confusing to have things like ST_Dump() and realize it really isn't an SQL/MM function.  I noticed when looking at SQL Server 2008 - that the functions that are not part of the spec they did not prefix with ST.. so it is easier to tell when you are using proprietary stuff.
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Håvard Tveite
Sent: Monday, July 21, 2008 7:06 AM
To: PostGIS Development Discussion
Subject: [postgis-devel] Function names in PostGIS
Regarding function names in PostGIS.
I was wondering if it would be a good idea to reserve the
"ST_" prefix for SQL/MM functions?
This would make it easier for users to know when they are
using "standard" functions and when they are using (the less
portable) PostGIS functions.  It would also save us trouble
if SQL/MM should introduce new a function with the same name
as a PostGIS function, but with different semantics.
Just a thought...
Håvard Tveite
Department of Mathematical Sciences and Technology, UMB
Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
postgis-devel mailing list
postgis-devel at postgis.refractions.net
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
