[postgis-devel] Function names in PostGIS
Mark Leslie mrk.leslie at gmail.com
Mon Jul 21 16:22:09 PDT 2008
This isn't a terrible plan, but it isn't the extent of what will need to
be done.  When we first made the move to ST_, it was for two reasons.
SQL/MM had finally given us a standard namespace to grab onto.  But it
was also a matter of isolating all the PostGIS functions from the
PostgreSQL standard functions.  This is still something we should try
and do.  If we change the namespaces (and I realize I'm using the term
fairly loosely)  we really should provide namespace prefixing for the
SFSQL functions, as well as the ESRI compatible functions, and then
provide yet another for PostGIS only functions.  This would result in a
number of redundant names, as SFSQL and SQL/MM have much functional overlap.
Mark Leslie
Geospatial Software Architect
LISAsoft
Ph: +61 2 8570 5000 Fax: +61 2 8570 5099 Mob: +61
Suite 112, Jones Bay Wharf 19-21 Pirrama Rd Pyrmont NSW 2009
LISAsoft is part of the A2end Group of Companies
http://www.ardec.com.au
http://www.lisasoft.com
http://www.terrapages.com
Obe, Regina wrote:
> I had the same thought too, but thought it would be too confusing to people to go back and change all those so didn't care to voice the concern.  Moving forward is a good idea I think.
> It is confusing to have things like ST_Dump() and realize it really isn't an SQL/MM function.  I noticed when looking at SQL Server 2008 - that the functions that are not part of the spec they did not prefix with ST.. so it is easier to tell when you are using proprietary stuff.
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of HÃ¥vard Tveite
> Sent: Monday, July 21, 2008 7:06 AM
> To: PostGIS Development Discussion
> Subject: [postgis-devel] Function names in PostGIS
> Regarding function names in PostGIS.
> I was wondering if it would be a good idea to reserve the
> "ST_" prefix for SQL/MM functions?
> This would make it easier for users to know when they are
> using "standard" functions and when they are using (the less
> portable) PostGIS functions.  It would also save us trouble
> if SQL/MM should introduce new a function with the same name
> as a PostGIS function, but with different semantics.
> Just a thought...
