[postgis-devel] Issue 70 in postgis: ST_NPoints Crashes with Curves
codesite-noreply at google.com codesite-noreply at google.com
Thu Nov 6 23:58:30 PST 2008
Issue 70: ST_NPoints Crashes with Curves
http://code.google.com/p/postgis/issues/detail?id=70
New issue report by robe.... at cityofboston.gov:
What steps will reproduce the problem?
1) SELECT ST_NPoints(ST_LinetoCurve(ST_Buffer('POINT(1 2)',3)))
What is the expected output? Either a warning or a number
What do you see instead?
It crashes - kills Postgres backend on Windows 2003 1.3.3 - have to restart
the service
On OpenSUSE 11 with latest 1.3.4SVN - I get this lovely message
SELECT ST_NPoints(ST_LinetoCurve(ST_Buffer('POINT(1 2)',3)));
server closed the connection unexpectedly
	This probably means the server terminated abnormally
	before or while processing the request.
The connection to the server was lost. Attempting reset: WARNING:
terminating connection because of crash of another server process
DETAIL:  The postmaster has commanded this server process to roll back the
current transaction and exit, because another server process exited
abnormally and possibly corrupted shared memory.
HINT:  In a moment you should be able to reconnect to the database and
repeat your command.
Failed.
Issue attributes:
	Status: Accepted
	Owner: robe.... at cityofboston.gov
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
