[postgis-devel] possible st_estimated_extent improvement: use root of R-tree
David Fuhry dfuhry at acm.org
Tue Oct 7 08:23:27 PDT 2008
It seems to me that the accuracy of st_estimated_extent could be
improved by looking at the root entry of the column's spatial index, if
one exists.  In that case, the result would be nearly exact, save only
double => float roundoff error.
Except in the case of deleted outlier entries without a VACUUM or
REINDEX, of course.  But that case would be no worse than using
statistics, as is currently done.
In any case, it should be a cheap lookup.
Thoughts?
-Dave
