[postgis-devel] possible st_estimated_extent improvement: use root of R-tree
Paul Ramsey pramsey at cleverelephant.ca
Tue Oct 7 09:09:32 PDT 2008
Sounds good, make it so! :) I think the devil is in the details, but I
can't remember what the details are. Best wait until MCA weighs in.
P.
On Tue, Oct 7, 2008 at 8:23 AM, David Fuhry <dfuhry at acm.org> wrote:
> It seems to me that the accuracy of st_estimated_extent could be improved by
> looking at the root entry of the column's spatial index, if one exists.  In
> that case, the result would be nearly exact, save only double => float
> roundoff error.
> Except in the case of deleted outlier entries without a VACUUM or REINDEX,
> of course.  But that case would be no worse than using statistics, as is
> currently done.
> In any case, it should be a cheap lookup.
> Thoughts?
> -Dave
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
