[postgis-devel] 1.4 SVN Compile problems
Kevin Neufeld
kneufeld at refractions.net
Fri Oct 10 08:16:55 PDT 2008
It could simply be that trunk is currently in an unstable build state.
(The autobuild is currently in a broken state as of three commits ago -
revision 3086). It errors out compiling lwgeom_geos.o
http://postgis.refractions.net:8082/
Cheers,
Kevin
Mark Cave-Ayland wrote:
> Obe, Regina wrote:
>> This is probably my ineptness at compiling, but I thought I would try to
>> experiment with 1.4 and got errors when its trying to compile the
>> loader. Errors below. If I go into lwgeom etc. other directories and
>> compile those separately, those seem to compile okay so seems to be just
>> the loader that is giving me problems.
>> What changed between 1.3.4SVN and 1.4SVN for the loader. I didn't have
>> problems compiling 1.3.4SVN.
>> The others just seem to be warnings (which I don't remember getting
>> before) except for this part
>> lkrb5 -lz -lreadline -lcrypt -ldl -lm -o shp2pgsql
>> /usr/lib/gcc/i586-suse-linux/4.2.1/../../../../i586-suse-linux/bin/ld:
>> cannot find -lkrb5
>> collect2: ld returned 1 exit status
>> This is on OpenSUSE 10.3 against a PostgreSQL 8.2.6 install
>> Thanks,
>> Regina
> Hmmmm looks as if the extra library dependencies are being added by PGXS
> for the PROGRAM target - I have no idea why it feels the need to do this
> though? The quick fix is to add the krb5 development headers which
> should be in a package named something similar to krb5-devel or
> libkrb5-dev.
> ATB,
> Mark.
