[postgis-devel] 1.4 SVN Compile problems
Obe, Regina robe.dnd at cityofboston.gov
Fri Oct 10 08:46:12 PDT 2008
Kevin,
I just realized I must be pulling from the SVN nightly snapshot since my
lwgeom compiles fine and has the old name lwgeom_geos_c.c.
Its just the loader I seem to be having trouble with.
Now if only I could make heads or tails of what Mark is saying I could
try that :). Guess I better go read.
Paul,
Whatever happened to your ground rules - Whatever you do don't break the
build. :)
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of
Kevin Neufeld
Sent: Friday, October 10, 2008 11:17 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] 1.4 SVN Compile problems
It could simply be that trunk is currently in an unstable build state.
(The autobuild is currently in a broken state as of three commits ago -
revision 3086).  It errors out compiling lwgeom_geos.o
http://postgis.refractions.net:8082/
Cheers,
Kevin
Mark Cave-Ayland wrote:
> Obe, Regina wrote:
>> This is probably my ineptness at compiling, but I thought I would try
to
>> experiment with 1.4 and got errors when its trying to compile the
>> loader. Errors below.  If I go into lwgeom etc. other directories and
>> compile those separately, those seem to compile okay so seems to be
just
>> the loader that is giving me problems.
>> What changed between 1.3.4SVN and 1.4SVN for the loader.  I didn't
have
>> problems compiling 1.3.4SVN.
>> The others just seem to be warnings (which I don't remember getting
>> before) except for this part
>> lkrb5 -lz -lreadline -lcrypt -ldl -lm  -o shp2pgsql
/usr/lib/gcc/i586-suse-linux/4.2.1/../../../../i586-suse-linux/bin/ld:
>> cannot find -lkrb5
>> collect2: ld returned 1 exit status
>> This is on OpenSUSE 10.3 against a PostgreSQL 8.2.6 install
>> Thanks,
>> Regina
> Hmmmm looks as if the extra library dependencies are being added by
PGXS
> for the PROGRAM target - I have no idea why it feels the need to do
this
> though? The quick fix is to add the krb5 development headers which
> should be in a package named something similar to krb5-devel or
> libkrb5-dev.
> ATB,
> Mark.
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
