[postgis-devel] 1.4 SVN Compile problems
Kevin Neufeld kneufeld at refractions.net
Fri Oct 10 09:59:13 PDT 2008
Yes, under a specific build, you can click "console output" that shows
the log file for that build.
ie, here is the log file for your last commit.
http://postgis.refractions.net:8082/job/PostGIS/200/console
And yes, I do ./configure before every build.
Thanx for fixing the break Paul.
Cheers,
Kevin
Paul Ramsey wrote:
> Does this buildbot have an error log anywhere? It's pretty hopeless to
> debug, it's not like I'm committing things that are broken for *me*,
> so I need to see what's broken for *it*. BTW, it'll need to re-run
> ./configure to pick-up the file re-naming.
> P.
> On Fri, Oct 10, 2008 at 8:16 AM, Kevin Neufeld <kneufeld at refractions.net> wrote:
>> It could simply be that trunk is currently in an unstable build state. (The
>> autobuild is currently in a broken state as of three commits ago - revision
>> 3086).  It errors out compiling lwgeom_geos.o
>> Cheers,
>> Kevin
>> Mark Cave-Ayland wrote:
>>> Obe, Regina wrote:
>>>> This is probably my ineptness at compiling, but I thought I would try to
>>>> experiment with 1.4 and got errors when its trying to compile the
>>>> loader. Errors below.  If I go into lwgeom etc. other directories and
>>>> compile those separately, those seem to compile okay so seems to be just
>>>> the loader that is giving me problems. What changed between 1.3.4SVN and
>>>> 1.4SVN for the loader.  I didn't have
>>>> problems compiling 1.3.4SVN.
>>>> The others just seem to be warnings (which I don't remember getting
>>>> before) except for this part
>>>> lkrb5 -lz -lreadline -lcrypt -ldl -lm  -o shp2pgsql
>>>> /usr/lib/gcc/i586-suse-linux/4.2.1/../../../../i586-suse-linux/bin/ld:
>>>> cannot find -lkrb5
>>>> collect2: ld returned 1 exit status
>>>> This is on OpenSUSE 10.3 against a PostgreSQL 8.2.6 install
>>>> Thanks,
>>>> Regina
>>> Hmmmm looks as if the extra library dependencies are being added by PGXS
>>> for the PROGRAM target - I have no idea why it feels the need to do this
>>> though? The quick fix is to add the krb5 development headers which should be
>>> in a package named something similar to krb5-devel or libkrb5-dev.
>>> ATB,
>>> Mark.
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
