[postgis-devel] 1.4 SVN Compile problems
Paul Ramsey pramsey at cleverelephant.ca
Fri Oct 10 10:22:53 PDT 2008
To answer Regina, no, I'm not getting build notices. The log *says* it
was sent to me, but it's neither in my inbox, nor my spam folder.
P
On Fri, Oct 10, 2008 at 9:59 AM, Kevin Neufeld <kneufeld at refractions.net> wrote:
> Yes, under a specific build, you can click "console output" that shows the
> log file for that build.
> ie, here is the log file for your last commit.
> http://postgis.refractions.net:8082/job/PostGIS/200/console
> And yes, I do ./configure before every build.
> Thanx for fixing the break Paul.
> Cheers,
> Kevin
> Paul Ramsey wrote:
>> Does this buildbot have an error log anywhere? It's pretty hopeless to
>> debug, it's not like I'm committing things that are broken for *me*,
>> so I need to see what's broken for *it*. BTW, it'll need to re-run
>> ./configure to pick-up the file re-naming.
>> P.
>> On Fri, Oct 10, 2008 at 8:16 AM, Kevin Neufeld <kneufeld at refractions.net>
>> wrote:
>>> It could simply be that trunk is currently in an unstable build state.
>>> (The
>>> autobuild is currently in a broken state as of three commits ago -
>>> revision
>>> 3086).  It errors out compiling lwgeom_geos.o
>>> Cheers,
>>> Kevin
>>> Mark Cave-Ayland wrote:
>>>> Obe, Regina wrote:
>>>>> This is probably my ineptness at compiling, but I thought I would try
>>>>> to
>>>>> experiment with 1.4 and got errors when its trying to compile the
>>>>> loader. Errors below.  If I go into lwgeom etc. other directories and
>>>>> compile those separately, those seem to compile okay so seems to be
>>>>> just
>>>>> the loader that is giving me problems. What changed between 1.3.4SVN
>>>>> and
>>>>> 1.4SVN for the loader.  I didn't have
>>>>> problems compiling 1.3.4SVN.
>>>>> The others just seem to be warnings (which I don't remember getting
>>>>> before) except for this part
>>>>> lkrb5 -lz -lreadline -lcrypt -ldl -lm  -o shp2pgsql
>>>>> /usr/lib/gcc/i586-suse-linux/4.2.1/../../../../i586-suse-linux/bin/ld:
>>>>> cannot find -lkrb5
>>>>> collect2: ld returned 1 exit status
>>>>> This is on OpenSUSE 10.3 against a PostgreSQL 8.2.6 install
>>>>> Thanks,
>>>>> Regina
>>>> Hmmmm looks as if the extra library dependencies are being added by PGXS
>>>> for the PROGRAM target - I have no idea why it feels the need to do this
>>>> though? The quick fix is to add the krb5 development headers which
>>>> should be
>>>> in a package named something similar to krb5-devel or libkrb5-dev.
>>>> ATB,
>>>> Mark.
>>> postgis-devel mailing list
>>> postgis-devel at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
