[postgis-devel] 1.3.4
Paul Ramsey pramsey at cleverelephant.ca
Fri Oct 10 11:22:02 PDT 2008
OK, I've made the prepared geometry work underneath the existing API,
so the key-based API has been removed.
Make sure you have the latest GEOS before trying these things, as
anything prior to the current revision still has leaks.
Paul
