[postgis-devel] Issue 22 in postgis: contains/within relationship problem
codesite-noreply at google.com codesite-noreply at google.com
Fri Oct 10 16:25:34 PDT 2008
Issue 22: contains/within relationship problem
http://code.google.com/p/postgis/issues/detail?id=22
Comment #2 by pwramsey3:
This is fixed in GEOS trunk.
Issue attribute updates:
	Status: Verified
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
