[postgis-devel] Issue 4 in postgis: Problem with LWGEOM_collect_garray - never returns MultiX from MultiX?
codesite-noreply at google.com codesite-noreply at google.com
Fri Oct 10 16:21:34 PDT 2008
Issue 4: Problem with LWGEOM_collect_garray - never returns MultiX from
MultiX?
http://code.google.com/p/postgis/issues/detail?id=4
Comment #2 by pwramsey3:
I'm not sure we want to change this behavior...
st_collect( set of polygons ) => multipolygon.
In this case you can still pull out the originals.
st_collect( set of multipolygons ) => multipolygon.
In this case you can't pull out the originals.
It seems hard to know.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
