[postgis-devel] Issue 4
Chris Hodgson chodgson at refractions.net
Fri Oct 10 16:39:03 PDT 2008
I think that what it is doing now is best - if you really want the other
behaviour you can do it with st_dump().geom, but if we change st_collect
to merge multi's together, I don't think it's possible to get the
current behaviour in any way. And the current behaviour clearly has a
use, being able to pull the collection apart and get back what you
originally collected up.
Chris
Paul Ramsey wrote:
> I'm interested in perspectives on this issue:
> http://code.google.com/p/postgis/issues/detail?id=4
> It's a behavior, not a bug. Do we want to keep it or not?
> P.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
