[postgis-devel] Issue 60 in postgis: Tarball of 1.3.3 has object files and .svn directories; impossible to build without clean on MacPro
Greg Troxel gdt at ir.bbn.com
Wed Oct 15 05:40:49 PDT 2008
  Issue 60: Tarball of 1.3.3 has object files and .svn directories;
  http://code.google.com/p/postgis/issues/detail?id=60
  Comment #2 by ke... at refractions.net:
  Fixed.  (For this tagged release as well as the branch and trunk tarballs).
  A ./configure and make is required to build the documentation that's
  included in the
  tarball.  This script was recently integrated into a new autobuild
  process, which is
  now cleaning up via a make clean before packaging up the tarball.
  Note: The PostGIS has not been under attack and the
  postgis-1.3.3.tar.gz does not
  have malicious content.  This file was updated to include a generated
  PDF of the
  documentation when the autobuild process went online a month ago.
Did you really replace a tarball with different contents?  That messes
up distribution systems which have stored checksums.  If so, I think you
should put the old one back and call the new one 1.3.3.1.
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081015/48882cf8/attachment.sig>
