[postgis-devel] Issue 60 in postgis: Tarball of 1.3.3 has object files and .svn directories; impossible to build without clean on MacPro
Kevin Neufeld kneufeld at refractions.net
Wed Oct 15 09:03:50 PDT 2008
On hind site, yes, you're right - the postgis-1.3.3.tar.gz should not
have been updated.  My bad.  At the time old scripts were being revamped
into an automated build process and the updated tarball was simply a
test of the new system.
I do still have the old tarball, but that was done well over a month
ago.  I can swap the files, but now folks like xander already updated
MacPro with new checksums.  Perhaps we should leave it since 1.3.4 will
be coming out very shortly here?
-- Kevin
Greg Troxel wrote:
>   Issue 60: Tarball of 1.3.3 has object files and .svn directories;
>   http://code.google.com/p/postgis/issues/detail?id=60
>   Comment #2 by ke... at refractions.net:
>   Fixed.  (For this tagged release as well as the branch and trunk tarballs).
>   A ./configure and make is required to build the documentation that's
>   included in the
>   tarball.  This script was recently integrated into a new autobuild
>   process, which is
>   now cleaning up via a make clean before packaging up the tarball.
>   Note: The PostGIS has not been under attack and the
>   postgis-1.3.3.tar.gz does not
>   have malicious content.  This file was updated to include a generated
>   PDF of the
>   documentation when the autobuild process went online a month ago.
> Did you really replace a tarball with different contents?  That messes
> up distribution systems which have stored checksums.  If so, I think you
> should put the old one back and call the new one 1.3.3.1.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
